Time span on Hydrograph
First time making a post.  This may have been discussed before, but is there a way to change the hydrograph output to minutes rather than hours.  I am trying to export the hydrograph and I need it in minutes.
RE: Time span on Hydrograph
export to Excel and divide by 60.
I think its multiply by 60.
You're right.  Have you tried it ?
If you want to change all the reporting to minutes, you can customize the time units in HydroCAD:
1) Open the project
2) Select Settings|Units
3) Click Custom
4) Scoll down and select the "RealTime" parameter
5) Change the maximum value to 9999
6) Change decimal places to zero
7) Change the short symbol to "m"
8) Change the long symbol to "mins"
9) Change the scale factor to "1/60"
10) Click OK
11) Repeat steps 6-10 for "TimeInc"
