Sub assembly-BOM
Sub assembly-BOM
Sub assembly-BOM
hi,
i have sub assemblies but i want to see just components of sub assemblies in BOM.. I dont want to dissolve my sub assemblies.Or i need to dissolve them in BOM. is it possible seeing components without sub assemly..
with all respect,
solidworks 2007 sp3.1
RE: Sub assembly-BOM
Select the Parts Only option in the BOM Manager.
cheers
thanks,
But i want to see some sub assemblies in my BOM.. So can i choose which one i will see or which one not to see.. except hiding from bom manager.. because when i hide subassembly name, i am not happy from item numbering..
In the sub-assembly, go to the configuration manager, right click on the configuration, select properties, either check or uncheck the Don't show child components in BOM when used as sub-assembly depending on whether you want the sub parts to show or just the sub-assy.
