How to recognise the elements included in a cercle
Hi everyone,
someone can please answer this question?
If for example one draws a circle on a given mesh. Is there any command in Ansys which allows us to recognize the elements whose centroid are included in this circle?
Barha
RE: How to recognise the elements included in a cercle
Yes, there is!
Try to write a macro using the commands etable and csys,,1. With etable you can define a table with all the centroids of the elements in a local cylindrical system. Then can reselect elements based on their x coordinates of the table esel,r,etab...
Alex
It's more complicate because it is an ellipse for me but I already tried something like you tell me and it works well, but a friend said to me that it could be a command in Ansys which gives us directly the elements included in the circle, do you think so Alex?
Barha
You can most certainly define an elliptical coordinate system...why not do that?
Can you Alex show in few lines how to do so?
See the command LOCAL...here'an an example though:
LOCAL,11,1,,,,,,,2  !defines CSYS 11 as a cylndrical coordinate system at global origin with y-axis to x-axis ratio of 2.00 (thus making it elliptical)
This command is fairly straightforward so hopefully this helps you out.
-Brian
I'll try it today Brian and i'll tel what i obtain.
thanks
