showing different Model Representations in the same drawing
can someone please tell me if i can show different representations of the same model within a single sheet on a drawing in Pro-E WF2?
I cant use different models to achive it as the models are all controlled parts and our QA system will not let me do this.
Arron
Arron
RE: showing different Model Representations in the same drawing
Showing models in a drawing is straight forward, I can't think what you mean...?
Adrian
I have different configurations generated using Reps and need them displayed on the same drawing.
Arron
-Hora
Had to create lots of instances and display them!! Very messy
– If anyone is listening Please, Please, Please let me use SolidWorks, heresy I know but . . . Engineers should not be spending time working out how to get Pro-E to do what they want.
The only people in our design office who like Pro-E, have never used anything else & they still struggle with Pro-E's lack of communication / usefull help . . ..Arghhhhh
There is a work-arround. Why not create an assembly, insert your part there, create the simplified reps of the assembly accordingly with the simplified reps of your part. And then put the assy in the drawing. There you can show your reps.
-Hora
- dansoarr
1- upgrade to Wildfire 3.0 (enables using simplified reps of parts in drawings) &
2- replace all simplified reps with family tables
Prior to WF1/2, you were able to show simp. reps of parts in drawings (the option was there). In WF, the option is grayed out in the Properties menu.
http://www.3dlogix.com
