Regeneration of TEA by degradation of TEG-TEA weak bonds
The issue in question is whether or not the pH adjuster chemical TEA will decompose at a lower boiling point than the 190-335 boiling point range (@ 5mmHg - 760mm Hg)when coupled to 4.5 pH TEG.
Will the pure TEA boiling point(s) above be lowered when the compound is part of a TEG-TEA solution?
