Cannot Mirror Components in an assembly
I am using 2007 Ver 3.0.
When I try to mirror something from a plane into a left or right version in an assembly it doesnt mirror. Instead it rotates.
Also, mirrored is checked but I cannot change the setting to instanced even if I wanted to.
RE: Cannot Mirror Components in an assembly
The default selection is (usually) an unchecked box in the Selections area (not the yellow area) which means the "Instanced component is used on both sides" option will be used.
What does the "AV" stand for that I need to disable?
But it sounds like this isnt a common problem so I need to reinstall.
Can I save my custom settings? Can I make a copy of my design library then overwrite the default folder in the new install?
AV = Anti-Virus
Yes you can save your custom settings. Start > All Programs > SolidWorks > SolidWorks Tools > Copy Settings Wizard.
Your Design Library should be created outside of the SW install folder and the Tools > Options > System Options > File Locations should be used to point to it.
Before you re-install, just confirm that this is what you are seeing but cannot alter;
http://img
No, I can change the mirror plane and selection. It's the upper yellow box that I cannot change. Its stuck on mirrored (even though that is the option I want, I thought it was odd that I couldnt change it).
The box next to the actual selection (in the salmon pink area) is the one that is selectable.
You don't need to re-install.
Instead of: b | d
I get: p | d
(where | is the plane)
