What does LDT stand for (used in context with PFD, P&ID)?
Thank you in advance for comment.
What would the acronym LDT stand for?
This regards an RFP that refers to preparation of PFD (process flow diagrams), P&ID's (piping and instrumentation diagrams), and LDT's. Coudn't find LDT on my favourite acronym website either.
http://www.acronymfinder.com//noacronym.asp
Cheers
Wayne
Cheers
Wayne
RE: What does LDT stand for (used in context with PFD, P&ID)?
If a DP cell is used for level measurement then maybe somebody figured that LD was more appropriate (or if the level is not absolute with reference to the bottom)?
Best Regards
Morten
Cheers//
Best Regards
Morten
Line Designation Table! That's the "thing" I like to see on the bottom of my PFD's! Yeah, the line list. Now I can see why folks may like to have it separate from PFD's, so as not to clutter PFD's ... and they call it an LDT.
Thank you very much!
measured variable position L stands for level, modifier position D is differential or users choice, output fuction T stands for transmitter. Since the Second position D is users choice. The following could be true, LDT is a "level displacement transmitter" or it could be a "level differential transmitter". There ought to be a legend around somewhere that spells this out for you.
If in doubt, call the Instrument Eng. Group to decode for you.
It turned out that what I had was indeed a line designation table or line list or line schedule.
A day doesn't go by without learning something
The original post didnt tell you exactly where the agronym way foudn. I initially misunderstood it and though it was on a drawing but i think that was cleared in a later post.
Best regards
Morten
