Singularity detected
Just about everytime I run a model I create, it detects a singularity or a non-positive definite. I've tried the suggestions given by the respective help topic but they never work. The only way I've found to solve the issue is to find that node and remesh around it. I usually do that to about 10 to 15 times before it will run without any error messages. Is there something I'm not doing properly when constructing the model? Is there an easier way to fix the problem than remeshing the local area? The model has only shell and beam elements.
RE: Singularity detected
Have a look at the thread below
thread727-85105: Checking the FEA quality
