Fatigue analysis on ring springs
I'm trying to analyze fatigue behavior in compression rings, and was wondering if anyone could help me find appropriate loading, size, surface etc. factors I could use for my calculations. Most of the data published are for beams in bending. Any help would be greatly appreciated.
RE: Fatigue analysis on ring springs
http://israelkk.googlepages.com/home
Also I think you'll find the ID increases in compression.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I do not think prabeshlohani refers to compression coiled spring made of wire (at least he didn't say it even though I asked for clearer info). To my understanding from the post he is referring to one piece metal ring. At least my post was for such a spring. But, you may be right because many times people do not bother to inquire for correct names of springs thereby create confusion.
Cheers
Greg Locock
http://geocities.com/prabeshlohani/temp/spring.JPG
Thanks for the help.
http
http://
