plasticity
plasticity
plasticity
I'm doing a plastic analysis ( perfect plasticity ) and I get this warning before the analysis stops
 ***WARNING: THE STRAIN INCREMENT HAS EXCEEDED FIFTY TIMES THE STRAIN
TO CAUSE
             FIRST YIELD AT --- POINTS
 ***WARNING: THE STRAIN INCREMENT IS SO LARGE THAT THE PROGRAM WILL
NOT ATTEMPT
             THE PLASTICITY CALCULATION AT --- POINTS
Does sobdy know something about that?
bat585
RE: plasticity
Have you tried to reduce the increment size?
If that not work, try to run it with elastic material first to debug any protenial problem.
RE: plasticity
all is ok in elastic case
I'll try to reduce the increment and tell you if it's ok...
Thanx
bat585
RE: plasticity
There was a similar post before, and it is helpful. I solved the same problem with slightly increasing the slope of the plastic part.
I hope this helps
RE: plasticity
Thank you for answering.
My load is a temperature predefined field, therefore I cannot do like it is suggested in the post you showed me.
I will try with a hardening model like you said.
Thank you !
bat585
RE: plasticity
In fact, even if I use an hardening model, those Warnings appear...
I think Abaqus can calculate but uses very short time increments (1e-7)
No way to change that?
bat585
RE: plasticity
if the problem work with small increment. Is that the problem sloved?
I assumed that you have a big area that under plastic, hence big nonlinearity.
