Cascade Fountain Incrustation
What´s the best system to keep clean a black marble cascade fountain?
We are trying different types of filter and systems but the mineral incrustation problem is a constant.
RE: Cascade Fountain Incrustation
For good water treatment, I start with a water analysis - send it to a good lab.
With the water analysis, most water purification vendors can come up with a solution.
The two times I have been involved with water problem, the root cause was that the original sample sent to the lab was not representative of the water we were using - not sure where the sample was taken or how, but it wasn't representative.
This is the best advise I can give.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
