Zero, small, or negative element area?
Hello Everyone,
I received the following error message while running the simulation.
"Error in job try: The area of 505 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. The elements have been identified in element set ErrElemAreaSmallNegZero."
The mesh is still very very coarse (seedEdgeByNumber, 2 or 4) and the sizes of the elements are quite uniform. Therefore the above message seems very wired to me. I cannot identify what is the problem with the elements. I appreciate it if you can give me some clue. Thanks!
RE: Zero, small, or negative element area?
Go to Visualization->Tools Menu-> Display Group->Create
Item : Elements
You should find an element set named "ErrElemAreaSmallNegZero".
But still I cannot identify the problem. This area of the elements in this region is the same as other regions.
I googled "ErrElemAreaSmallNegZero". It seemed that this is a problem common to 2D simulation. Some people suggested that maybe the normal to the elements on the surface is pointed to z- direction, and it should be reversed to z+ direction. But I don't know how to check on the normal of the problematic faces and how to reverse the face normal.
I don't now if you have meshed your part with abaqus pre proc or by yourself, but I had the same problem with a mesh I had generated by myself and I solved it by changing the order of the nodes on each element
Hope I helped
bat585
corus
