Design Tables in Assemblies
So here it is, I have several different configurations on a sinlge part that I have in assembly. What I am having trouble doing is calling out the specific configurations within the assembly. It seems to only want to show the default configuration. How do I change the different part configurations in an assembly?
RE: Design Tables in Assemblies
Right click on the part -> Select Component Properties and pick the configuration that you want from 'Referenced Configurations'
Hope this helps,
Lou
Check the Help file for design tables, configuration parameters > Summary of Design Table Parameters
