Coincident node removal
I am attempting to remove coincident nodes in the input file for an ABAQUS analysis.  I've heard that it can be done in the CAE, but I am not using that.  Any ideas of a keyword to remove the duplicates?
I've been using *mpc, tie to connect the nodes, but since there are a lot, I'd rather not have to.  It is an option, however.
Thanks!
RE: Coincident node removal
If there's a lot of them and they extend over an area of a surface then you could define the surface and then tie the two surfaces together.
corus
How good are those Tie surface? are they good enough even I use next to the area that is most intrested?
Tied surfaces will give beter results if the nodes are concident. If the nodes are on the same plane but offset then you can get interpolation errors and the results at the coincident surfaces will be noticeable. Creating the surfaces will be a problem though and personally I'd just go back and make a single part and avoid messy merging/tying nodes
corus
I've tried doing the surface definition thing, and it works to some extent (the biggest problem being where tied nodes are also part of an embedded element).
I'm basically just having problems modeling a structure that is repeated three times - I built the original part, then instanced it three times, and am trying to connect the junctions.  Unfortunately, even with them connected (using *mpc, tie) I'm getting numerical problems all over the place.
Thanks for the help, though.
