Copying Mirrored parts
Hi all (again)
I have a mirrored part and my client wants the left and right parts in seperate files, which means copying the mirrored part.
Is that possibal - to copy the mirrored part in a seperate file?
Rip
RE: Copying Mirrored parts
If I understand correctly, you have a single part file that has 2 solid bodies (1 is the right side, and then you mirrored that body to create the left side version).
You have 2 options:
1) 'Delete Body' to remove the left side and Save as Part-Right Side. Then 'Delete Body' to the right side and Save as Part-Left Side. Now you have 2 files 2 parts.
 However, these files are no longer linked and a change to one will no tbe updated on the other. (But could be done manually)
2) Create an assembly with the part (delete out the mirrored body). Then 'insert' -> 'mirror component' and select the part and a plane to mirror it about. (Make sure that you properly ckeck the box to create a left/right version)
Now the part and its mirror are linked and any change you make to the original will be updated in the mirrored part thru the assembly.
-Lou
Thanks GLED,
I appreciate your help!!
RIP
