calculate water requirement for quenching
I am trying to calculate how much water will require to reduce the temperature of my gas flow from 1911 F to 1200 F
i have gas flow of 1448 SCFM and i am trying to reduce its temperature through water quenching.
can anyone tell me how i can use sesible heat of water and latent heat of water. becoz water will also change its phase from liquid to vapor.
Thank you,
RE: calculate water requirement for quenching
Process Design and Engineering Practice by Donald R. Woods (Prentice Hall) ISBN 0-13-805755-9, treats the subject with examples for direct contact heat and mass transfer.
