Wood girder truss Ply-to-ply connections
In a multiple ply wood truss girder that is supporting other trusses along the bottom chord, can the nailing of the metal truss hanger (assuming a three inch long nail) be used to transfer the loads from the face ply down to the second ply? Most truss drawings seem to use only the nailing specified on their drawings and disregard the nailing from the hangers which is penetrating the second ply.
RE: Wood girder truss Ply-to-ply connections
What does "supporting other trusses along the bottom chord"
mean ??  Are you talking about a solid glu-lam beam???
Are you talking about a 3 inch nail that will <supposedly> prevent the beam from pulling away from the face of the wall??
Answer is pretty simple. Yes. The issue is that the truss manufacturer is signing off on the girder truss, and the truss to truss connection, not taking into account any hangers. The hanger nails do help transfer the loads into the rear ply. The Simpson HUQ hangers offer even better transfer of loads using the SDS screws instead of nails.
Trussme68,
When you say "truss to truss connection" do you mean only the ply to ply connection of the girder.  My understanding is that the truss manufacturer is responsible for all truss to truss connections, including the connection for a truss hanging into a girder.  Thanks.
CJSchwart,
We are responsible for both ply to ply and truss to truss. We do specify the hanger required for the connection, but have no control over who installs it and how. Therefore we do not account for the hanger nails to help transfer the loads on face mount trusses.
