Import from Analysis Program - STAAD
OK... first post!
I discovered that the subject tool/task isn't as "easy" as maybe it should be. For example, I haven't figured out how to get member connectivity to "work" the way I expect it to; that is, everything's connected to each other at the endpoint centroid - in STAAD, Bentley Structural brings this in with some members connected at enter, some at top of beam.
I've also only got three choices of timber member parts: studs, wood posts and what's the other one? Can't remember now...
