joining structures of different densities
Dear all,
I want to model the influence of an accelerometer on the natural frequency of a structure. I have not used I-deas for several years and am quite rusty now.
How can I "join" the accelerometer to the structure, but still have a separate mesh as the accelerometers density is different.
Thanks in advance
PS. I use I-deas9
RE: joining structures of different densities
First join both volumes and then do a separate. In the mesher you should be able to select each volume. The meshes will be joined at the interface.
