Steel frame masonary wall connection
I am working on the construction of a small warehouse builing 60' X 40'. The building is a steel framed building with masonry blockwork as the walls. I am looking for the best means to connect the steel frame and masonry blockwork, in particular the steel column masonry block wall connection or the steel beam masonry block connection…
SN
SN
RE: Steel frame masonary wall connection
JedClampett makes a good point that the connection detail will be different depending on what you are trying to accomplish.
If you are simply trying to brace the top of the wall so you don't have a cantilevered wall, we have used a bent plate welded to the WF and epoxied into the CMU.
