Lightening Arrestor IR value
Dear all
Could you anybody tell the reasons for low Insulation resistance of 220kv/400kv Lightening Arrestor?
In our substation we got the following values
Test Voltage: 5000v dc
Meggar make Insulation Resistance instrument
Top stack : 7.5 Mega ohms
Bottom stack : 175000 Mega ohms
Total stack: 200000 Mega Ohms
LA is in service in 220kv Main Bus-II. However during Preventive Maintenance checks we identified above values recently.
As LA is completely sealed. The what are the factors effect this Low Insulation resitance values.
RE: Lightening Arrestor IR value
The most common failure mode for arresters is moisture. The comparative test on a good arrester would help determine this. I've observed seals in which a gasket was improperly installed that allowed moisture to enter the arrester housing. Unfortunately, from a forensics standpoint, you usually have to chisel off the sealing area (assuming it's a porcelain housing) to find this.
