Insert "NON CONTROLED COPY" in header while printing
I need to insert a note in every drawing that I plot saying that it is a "non controled copy".
I believe it can be done with a journal file, or maybe there is another way ?
I have an example of a journal file that should do what I want, but I can“t make it work: probably because I need to change certain thing in it like paper size or printer name??
Any way, here it is. Thanks a lot.
' NX 3.0.0.10
' Journal created by geolekas on Fri Mar 05 15:18:51 2004 Eastern Standard Time
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Drawings
Imports NXOpen.Annotations
Imports System.Text
Module NXJournal
Sub Main
' This example opens up a part, cycles through
' all the sheets in the part. For each sheet, it updates
' all the views on it. It then places a in the upper left corner
' that has the current date on it. And then the example plots
' the sheet. (Currently this is not implemented, instead it
' popups a message box.) And then it deletes the note just
' added to the sheet. And once done with all the sheets
' the part is closed.
' NOTE: This example is setup to place a note correctly for
' an E size drawing.
' If you want do not want to delete the note that is created,
' change the constant value of DO_NOT_DELETE_NOTE to be 1.
#Const DO_NOT_DELETE_NOTE = 0
Dim theSession As Session = Session.GetSession()
' Menu: File->Open...
' Fill in part location on the OpenDisplay line.
Dim part1 As Part
part1 = theSession.Parts.Work
Dim drawingSheets As DrawingSheet()
Dim mySheet As DrawingSheet
drawingSheets = part1.DrawingSheets.ToArray
Dim dfviews() As DraftingView
Dim dfview As DraftingView
' Here we loop through all the sheets in the part.
' For each sheet, we open the sheet, update all views in it,
' And then plot it. Unfortuantly, as of the time of this demo, Plot has
' been implemented for journaling. So we will pop-up a message box listing the
' views on the sheet.
For Each mySheet In drawingSheets ' Iterate through elements.
Dim session_UndoMarkId1 As Session.UndoMarkId
session_UndoMarkId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Open Drawing")
mySheet.Open()
' Menu: Edit->View->Update Views...
Dim session_UndoMarkId2 As Session.UndoMarkId
session_UndoMarkId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Drawing View Update")
'There are a couple of ways to update all the views in the part
' we will use the update all views in sheet method, vs. building up
' an array of views to be used for update.
theSession.Parts.Work.DraftingViews.UpdateViews(DraftingViewCollection.ViewUpdateOption.All,mySheet)
' Menu: Insert->Annotation...
Dim session_UndoMarkId3 As Session.UndoMarkId
session_UndoMarkId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Create Annotation")
Dim letteringPreferences1 As LetteringPreferences
letteringPreferences1 = theSession.Parts.Work.Annotations.Preferences.GetLetteringPreferences()
Dim userSymbolPreferences1 As UserSymbolPreferences
userSymbolPreferences1 = theSession.Parts.Work.Annotations.NewUserSymbolPreferences(UserSymbolPreferences.SizeType.ScaleAspectRatio, 1, 1)
Dim TimeNote As DateTime
TimeNote = System.DateTime.Now()
Dim TimeNoteString as String() = TimeNote.GetDateTimeFormats()
Dim stringArray2(1) As String
stringArray2(0) = "<c3.3.25> Printed on:"
stringArray2(1) = TimeNoteString(0) + "<c>"
Dim point3d1 As Point3d = New Point3d(40.8263111888112, 33.145541958042, 0)
Dim note1 As Note
note1 = theSession.Parts.Work.Annotations.CreateNote(stringArray2, point3d1, AxisOrientation.Horizontal, letteringPreferences1, userSymbolPreferences1)
theSession.SetUndoMarkVisibility(session_UndoMarkId3, "Create Annotation", Session.MarkVisibility.Visible)
letteringPreferences1.Dispose()
userSymbolPreferences1.Dispose()
' Print will go here
dfviews = mySheet.GetDraftingViews()
Dim sheet_name As String
Dim view_names As StringBuilder = new StringBuilder()
sheet_name = "Printing Sheet: " + mySheet.Name
view_names.append("Sheet contains the following views: ")
For Each dfview in dfviews
view_names.append(dfview.Name +" ")
Next
Windows.Forms.MessageBox.Show(view_names.ToString(), sheet_name)
#If DO_NOT_DELETE_NOTE = 0 Then
' Menu: Edit->Delete...
theSession.UpdateManager.ClearErrorList()
Dim session_UndoMarkId5 As Session.UndoMarkId
session_UndoMarkId5 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete")
Dim integer4 As Integer
integer4 = theSession.UpdateManager.AddToDeleteList(note1)
Dim integer5 As Integer
integer5 = theSession.UpdateManager.DoUpdate(session_UndoMarkId5)
#End If
Next
End Sub
End Module
' NX 3.0.0.10
Option Strict Off
Imports System
Imports NXOpen
Imports System.Text
Module NXJournal
Sub Main
Dim part1 As Part
mySheet.Open()
Dim note1 As Note
Next
#End If
Next
End Sub
End Module
RE: Insert "NON CONTROLED COPY" in header while printing
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
http://www.siemens.com/ugs
