Measuring low current
Hi, I'm trying to measure the average current going to a LED that has PWM (100kHz). I used to use a 10 Ohm resistor and a 100uF cap in parrallel that I would put in line with the LED. Problem is that 10 ohm has too much impact on the circuit, using a smaller resistor like 1 ohm or .1 ohm would be perfect but then, how accurate is a digital multimeter when it come to 100uV to 100mV...
Any suggestions on how I can pull this off. Is there some good products around for my needs? Should I go with an Op-Amp ... I doubt an Op-Amp would be precise enough for uV and low mV ?
Frederic
Frederic
RE: Measuring low current
You should be using an oscilloscope or a data acquisition system.
TTFN
I would try and use the current range of the multimeter and short out the PWM frequency with a bypass capacitor. Here, you may need the 1000 uF plus an HF capacitor because the resistance of the DMM is rather low.
But, of course, an oscilloscope that measures voltage drop across a 1 ohm (non-inductive!) resistor is a better technique. Especially if your scope has built-in math to calculate average current from the actual waveform. Yes, AVG, not RMS, it is AVG that produces the light.
Gunnar Englund
www.gke.org
Use a solid dielectric capacitor as suggested above. You want a DVM with a 20mV full scale setting. If you turn the circuit off and check the zero first the accuracy should be ok. If you are looking for good efficiency in the overall circuit you should chop at a lower frequency.
Pulsed LEDs are often run at much higher currents than statically driven devices.
TTFN
Presumably there is a capacitor immediately upstream of the switch transistor / FET? Can you break into the supply there and measure the average current?
Sometimes I only open my mouth to swap feet...
If it's a system do what everyone else does. Monitor the system current with the LED commanded off then measure the 'system' current with the LED being PWMed. You will get the actual system current contribution caused by the LED being driven.
Keith Cress
http://www.keithley.com/data?asset=359
TTFN
I'd posted the information on the Keithley meter primarily for your information based on your comment "I'd find it hard to believe that your DMM is capable of reading 100 kHz voltages at any resolution". Perhaps you forgot to include the qualifier "... on a DC measurement range".
As this is a square chopped signal there will be significant harmonics above 1MHz which would render useless the measurement taken using a 300kHz B/W meter if reasonable accuracy was required.
Turning the drive into psuedo-DC is potentially going to change the thermal conditions in the LED significantly, resulting in a different I-V behavior than when it's pulsed.
TTFN
The reluctance may come from unavailable scope?
Gunnar Englund
www.gke.org
I have to go back on that. The cap does only short HF around the measuring shunt. And that's what it is supposed to do.
Current limiting for the LED is already there. So, no probs with the cap.
Gunnar Englund
www.gke.org
The scope is going to want to ground one end of the sense resistor. The circuit might not be this way up.
There is going to be a shed loadf of common-mode noise on that point anyway so you would need to do a null reading with probe and ground lead shorted together to establish the "zero" level, which may not be zero and might therefore need to be subtracted.
Actually the capacitor helps give you the mean level, so the DVM bandwidth is irrelevant. You don't need or want any bandwidth in the DVM. A 20ms integration time (or longer) would be ideal.
The capacitor/resistor pair is not supposed to be the current limiting part of this circuit. Hence the capacitor does not blow up the LED!
> Use a differential scope
> Use an op amp based unity-gain buffer to covert to single end
> Use a current probe with the oscilloscope.
TTFN
Obviously, everything is relative, but a cheap oscilloscope is only around $330:
http://
add an op-amp with 5 or 6 resistors for around $3.
Or go really cheap:
http://s
TTFN
As per Skogsgurra, to get the average reading, put a resistor in SERIES with the volt meter, and the capacitor across the meter itself. This will allow the PWM current to switch normally through the LED and your current sense resistor, and apply a filtered average to the meter.
Something like 1k will isolate your capacitor from the 1 ohm sense resistor, and a 0.22 uF will filter out the 100 kHz nicely. Use a good plastic cap. Polypropylene of you can get it, otherwise mylar shold be adequate. You might also put an NPO ceramic cap of several hundred pF across the plastic cap to filter out the highest harmonics.
I've nothing against using a scope, but for a quick, easy measurement, DMMs are dandy. Especially if you're in an isolated place and don't have a nice battery operated scope around like some folks do.
Build the same circuit but use a dc sorce.
Adjust the led until its as bright as the
other one , then read the current.
I personally would use a scope if one is
handy.
I have a USB card that cand read up to 2000 samples per second.
I wanted to use the digital multimeter because it is floating and therefore a lot easier to avoind ground issues.
Madcow: LEDs light intensity can vary a lot between each of them the human eye is all but good at detecting light intensity. Anything under 2x the eye will not see. So, the eye would not see the difference between 2000 mcd and 3000 mcd.
Jimkirk, that sound like a good plan I'll check for that.
Thanks everybody
Beerbaron
a resistor (the same as the sense resistor)
with a dc current.
Adjust the current until they read the same
temp.
Ummmm! Beeeeeer!
But I am all for the beer!
Gunnar Englund
www.gke.org
Nobody has mentioned "Depth of water sensing".
thread240-58310: Depth of water sensing
LOL
Gunnar Englund
www.gke.org
