Microstation Text problems! HELP!
I have converted an AutoCAD 2004 file into Microstation V8. That works fine. But when I attach this file to another V8 file some of the text doesn't show. The text that does not show is a different font that the rest of the text that DOES show. I've tried matching the properties and font of the text that does show up but it still doesnt work? Can anyone help?
Thank You!
Thank You!
RE: Microstation Text problems! HELP!
orelse you may have to change the active view depth to accomodate the changes in range.. look up help on active view depth... changing to 2d looses your RL's or Z values and in civil drafting we need this alot!.
I want to set all the text in the drawing in to an general type( the same with and height ).
Thanks! Emergency...
1) select all of the text with a fence or the element selection arrow
2)change the selected text to one style and size with the "Change Text Attributes" tool.
Let me know if you need more information.
-Bob
