fiberglass tubing
fiberglass tubing
fiberglass tubing
Hello all,
I am looking for a non-conductive fiberglass tube.
this tube needs to be approx. 7/16" OD by 5/16" ID..and it needs to be able to withstand 2000 psi of hydraulic oil..
I have been looking everywhere locally and no one carries this stuff..
any help would be appreciated..
thanks,
brent
RE: fiberglass tubing
I've used FRP tube in larger sizes, and found that you had to pay extra to get a good surface finish on the outside ... and that surface was cosmetically very nice, but not uniform enough to use with an o-ring.
So, assuming you can get the stuff, how do you terminate it?
Mike Halloran
Pembroke Pines, FL, USA
