Drawing Links
Drawing Links
I am trying to update my drawings at the latest engineering level, basically to re-link the views of each drawing to the new 3D math data received. I do not know why some of my drawings do not accept the new 3D files. The error message is: " The link refused the document". I have used Edit/ Link/ Replace. Did anybody have this issue before?
Rob
Rob
RE: Drawing Links
Your drawing remebers the UUID of the original part
used to create it.
It now wants a part with the same UUID number
or else it will refuse relinking
Nev
RE: Drawing Links
Yes, the new file which I would like to have it linked to the drawing has a different UUID, it is a new engineering level for the part. Also I will create another drawing from the existing one, so the UUID will be different.
How can I determine the UUID of the file? Can it be modify?
Rob
RE: Drawing Links
You can't modify the UUID or determine this number (at least I don't know how to). See also http://www.eng-tips.com/faqs.cfm?fid=1318
Fernando
RE: Drawing Links
RE: Drawing Links
The UUID cannot be modified.
It is however possible to relink via coding(CAA and or VBA).
We have done it successfully this way using our inhouse
programmers
Neville
RE: Drawing Links
Thank you very much for your help.
Rob
