Steel Pipe Encased in Concrete Pier
This is a typical flag pole type situation.
What is wrong with simply dropping a steel pipe in a hole and encasing it with concrete??  Don't worry about sizing of pipe or pier - that has been worked out.  Structure is not for occupancy - literally a flagpole type application.
I assume that rust is the only real problem and if so - are there simple measures to prevent it.
Thanks for any help.
RE: Steel Pipe Encased in Concrete Pier
Is it a flagpole or something else? If it were a flagpole, there's nothing wrong with the concept per se. You still need to treat it as a drilled pier and would need to provide confinement reinforcement. If you need to replace the flagpole someday, it won't be easy to remove.
Three flag poles in a 60 x 60 x 70 triangle supporting a tent type canopy.
Good point on replacement --- but probably never happen.
I have done this for a numbe of projects from 3" square to 7 foot diameter, to support signs. As long as there is at least 3" of concrete cover, rust should not be a problem.
You can insert the poles into the wet concrete or pre-insert.
Another optin that cab be used for granular soils, the pole can actually be virated down to the required depth. Needs to be galvanised.
csd
Thats a thought --- I could pile drive it in....
Tnx
