Cantilevered abutment wingwalls
I am working on a bridge where I have a full height "retaining wall" abutment supported on piles. My question is really on the wingwalls for these abutments. Because of some utilities in the area that cannot be moved, it will be difficult to have the wingwalls supported on piles.
I was thinking of having the wingwalls cantilever off of the abutment. That way I wouldn't need any kind of footing or piles, and I would minimize my interference with the utilities. The wall would cantilever back approximately 24' from the front face of the abutment. Is this too far? What have people in other states typically done? Any recommendations/insight would be appreciated.
RE: Cantilevered abutment wingwalls
I've done and seen some odd things with wingwalls & abutments. Can you use a soldier pile & lagging wall?
Limits that i've seen vary from 15 to 21 feet and the work beyond that depends on the type of abutment (open seat or integral).
For integral greater than 15-20' some states show details of a pile supported retaining wall (unless rock is shallow). And for for open seat retaining walls the above applies but if the wall isn't too much greater than 15-20' the wall is placed on a single pile at about the 3/4L point.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Have you considered mechanically stabilized earth retaining walls? They do not need to go deep. You could make them continuous across the front of the abutment and have a stub abutment on piles behind.
I believe the Caltrans Bridge Design Manuals are all available on-line as pdf's.
Bridge Design Aids
Bridge Design Details
Bridge Design Practice
Bridge Design Specifications
Bridge Memos to Designers
Standard Plans
