Where Can I Find Info on Oil Well Threads
I am designing a piece of equipment which will require two shaft lengths, depending on the application.  My boss told me to use a basic shaft with an extension, using oil well threads to attach the extension when necessary.
I can't find any dimensional or other data on oil well threads.  My boss doesn't have any information either.  Is there another name for these threads, or is it an out-dated standard, or is there even such a thing as oil well threads?
Thanks.
Phil
RE: Where Can I Find Info on Oil Well Threads
I believe they're often referred to as API threads.
Software For Metalworking
http://mrainey.freeservers.com
Buttress threads are used frequently.  A standard that covers this area is API RP 5B1 Threading, Gauging, and Thread Inspection of Casing, Tubing, and Line Pipe Threads.
http://apistandardsonline.api.org/servlet/ControllerServlet?Action=DisplayPage&;Env=BASE&Locale=en_US&;SiteID=api&id=ProductDetailsPage&productID=33238900
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
