Repair of compression molded rubber
We have nitrile and neoprene parts compression molded under high pressure. Once the rubber product is complete, we machine parts of the molded rubber part to various configurations. Sometimes voids below the surface are discovered during the machining process. Most of the time these voids do not impact the performance of the molded part, but the voids are visually unacceptable. We have tried RTV to repair and they look worse. We have used MEK to dissolve rubber 'dust' and create a paste to fill the voids. Not great success. Is there a method to repair molded rubber products and create a good bond with the parent rubber and blend the repair visually? We have confirmed the function is not compromised with the voids but we cannot send these blemished parts to our customers. -Awol
RE: Repair of compression molded rubber
* A "bump" is the application of low pressure on the mould for a few seconds followed by slightly opening the press before re-applying low pressure.
