CutList
CutList
Hi all,
I have a file with a weldment cutlist.
On the model is 4 items but on when I try to do a drawing, only 2 items appear. I need to see the 4 items.
Any suggestions?
Thanks!!
Rip
RE: CutList
There are many things that can cause this.  One thing to look at is: are the four items different sizes or do you have two of one size and two of another?  Another is: were the cutlist folders created manually or automatically (you do not indicate which version of SolidWorks you are using?
Regg
RE: CutList
Using SW 2007 SP 3.1
RE: CutList
1. Five items are different sizes
2. Cutlist folders created automatically
RE: CutList
Where was the cut list created in the as welded config or as machined?  Can you post your model?
Regg
RE: CutList
Hi Regg.
I cannot post the thing, sorry. bigcheeks
RE: CutList
Hey..sorry about the big cheeks thing...it was supposed to show a picture; instead the discription came up!!!
RE: CutList
That is okay (maybe I have a big b__t or did you mean my face bigears).  Did you get the problem solved?  One other thought.  Do you have five separate bodies or did you accidentially merge a couple?
Regg
RE: CutList
LOL..
No comment on the butt or face!
No problem still there...and, no..I did not merge a couple...thanks for mentioning that, though....
RE: CutList
Hi all.
Are there any other solutions I could try?
Rip
RE: CutList
Ripper2,
You still did not answer my question.  How many cutlist folders do you have in the model?
Regg
RE: CutList
Hi Regg..5 cutlists....
Rip
RE: CutList
In the Part file...which configuration was the Cutlist Items created in?
Which configuration are you using in your drawings view?
Ken
