Purge Command?
Purge Command?
Purge Command?
I'n AutoCAD as I'm sure a lot of you are aware, there is a purge command to removed linetypes, fonts etc that are not used... is there something similar in SE?
Cheers,
M
RE: Purge Command?
(sorry for the shockingly bad grammar in my post... I hadn't had my first cup of coffee when I typed it... still not too awake now)
