Hemispherical Heads
Hemispherical Heads
Hemispherical Heads
Is there a formula for calculating the weight of a hemispherical head?
RE: Hemispherical Heads
Rick,
D= diameter of head in feet
Surface area in sq. ft. A=1.571*D^2
t= thickness in inches
Density of steel = 40.8 lbs/in/sq. ft.
weight lbs = A*40.8*t
HTH
I have been doing volumetric calculations and just knew there must be a quicker way
