Diesel fuel flow sensor
I am trying to measure fuel consumed by a Bobcat mini excavator with 60 hp Kubota diesel. I just need to have an accurate total of gallons used. I'm assuming I will have to put a flow meter on the fuel line as well as on the return line.
Does anyone have any suggestions?
RE: Diesel fuel flow sensor
Double meters would double the margin of error. Is there a reason you can't install a locking gas cap and simply measure the amount of fuel placed in the tank?
-Reidh
Mike Halloran
Pembroke Pines, FL, USA
