attaching to SS sheet metal
What would be the best way of attaching something to a stainless steel sheet, so it does not separate? I am afaid that the object will shear off at the points where it is fastened with screws. BTW, there is plywood behind the sheet metal, which is not a great base for the screws to anchor to.
Any suggestion of alternative fasteners?
RE: attaching to SS sheet metal
- under what load, i.e. force?
- in what load directin, i.e. pullout, shear, etc.
- in what environment?
- from how thick a sheet?
- of what stainless alloy?
In general, the answer is that any joint can be made to separate, somehow, so your answer is the null set, unless you constrain the problem.
Mike Halloran
Pembroke Pines, FL, USA
B.E.
... maybe a toilet paper holder?
Mike Halloran
