Internal Dimensional Analysis of a small socket
Anybody have a good idea on how to find accurate dimensions on the inside of a small socket (ethernet style) and its corresponding connector. I tried using camera one of my suppliers has that will zoom in and measure for you but its not very accurate on the inside of the socket. I might have to pack it in Bake-Lite, cut it, and then measure it.
RE: Internal Dimensional Analysis of a small socket
Another approach would be to find a microscope with a measuring reticle or just a crosshair if it has an X-Y stage.
I have used the method you propose numerous times, mounting by some means and cutting with a low speed diamond saw. I would still use a microscope with the X-Y table.
http://www.newmantools.com/flexbar/repl.htm
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
