Reinforcing Inserts at Construction Joint
I am designing a concrete slab that will stop short of a complete slab pour due to construction constraints. I am looking for a tube/pipe insert to embed at the edge of the pour. I would like to insert dowels into the tube/pipe when the remainder of the slab is to be poured. I am tryign to avoid casting the dowels in the first pour to avoid them sticking out until the rest of the slab is poured. Does anybody make such an item? Should I just go with a pipe that fits the dowel?
RE: Reinforcing Inserts at Construction Joint
For an example go to http://
http://www.danley.com.au/joints.htm
There is a lenton grout tube that gives a full strength tension splice.
http://www.erico.com/products/InterLock.asp
csd
http://www.ancon.co.uk/main.asp?pageID=122
If you don't want a movement joint, cast in threaded inserts (ferrules) and screw in rebar with a threaded end when required.
These are for shear transfer, not tension or moment.
