Wastewater Lagoon Discharge Streams
I'm working on a 14 acre wastewater lagoon that has no single well-defined discharge stream.  The are about 12 small (6’W x 4’D) discharge streams.  The locals are concerned that the lagoon is short-circuiting back upstream of their raw water intake on a nearby river.  We need to dam all these small streams, except for one, so we can measure the water quality.  The problem is that this is a very remote area and getting that many sandbags, 500-700 – 50lb’ers, will be very difficult.  I was thinking along the lines of Terra-Tubes stacked between rebar with some sandbags on top, but Terra-Tubes allow flow.  Does anyone have any suggestions?  Thanks,
RE: Wastewater Lagoon Discharge Streams
Place bentonite at face of discharge outlet dams.
