Which is the hardest
I have been presented with two ceramic materials, one has a Vickers hardness of 1300 HV 500gram and the other is 2500 Hv 250gram.
Which is the harder material?
RE: Which is the hardest
Just remember, hardness isn't everything. Even in wear applications you need to know a lot more than that.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
