Generator Exhaust Piping
Hello all.  First Post.  I have a problem with a generator exhaust pipe in a confined space.  The pipe exists the muffler with an ID of 10 inches.  My question is about a 90-degree sweep vs. a 90-degree fitting, and how much more back pressure will be given by the 90-degree fitting vs. the 90-degree sweep?  Am I really gaining that much by going with the sweep?  Also, is it that much trouble for a mechanical contractor to make the sweep?  I also thought about using two 45-degree fittings with some straight pipe to ease the turn.  Thanks!
RE: Generator Exhaust Piping
The back pressure question is really a question for the generator manufacturer. I've used a generator on a much smaller scale and had the same question. The generator manufacturer Onan indicated backpressure was a non-issue. This was for a 12Kw commercial generator.
For a contractor that has a welder and pipe fitter worth anything they should have no trouble fabricating a pretty elaborate pipe but do you need to?
Not enough information, but if the exhaust ID is 10 inches at the muffler, this is probably a large machine and probably turbocharged and the sharp bend may affect it.  I glanced at a handbook and the losses in a tight bend are approximately 4 times that of a large radius bend.  Best to contact the OEM, they have charts/graphs/programs to calculate losses in exhaust piping
Two 45's have more combined loss than one long-radius 90.  Each 45 is about 60% of a 90.
Depending on the overall system, it may be more advantageous and economical to simply upsize to 12" pipe than fabricate anything fancy...
