Removing a boundary condition
I'm trying to remove boundary conditions in the last step of a steady state analysis.
The problem is that the reaction forces are too important and  removing the boundary conditions implies a too big movement of one of my parts.
-> Fixed time increment is too large
What should I do?
Thanx
Bat585
RE: Removing a boundary condition
What happen when you changed the increment type to automatic instead of fixed and reduce the inital increment.
Hi !
It doesn't change anything because I'm in static general analysis. Do you know what king of analyis would be better?
Bat585
what material are you analyzing
It may be static but the analysis is still performed as a transient with a unit time and the boundary conditions ramped over that time. If by removing the boundary conditions you make the structure behave with rigid body motion then you won't get a solution anyhow.
corus
Ok thanks for your answers. In fact it is ok if I put enough increments.
