Welding simulation
Welding simulation
Hallo,
i'm looking for FEA software that would allow me to simulate the welding proces in time. Thanks for any suggestions.
Greetings,
jungi
Greetings,
jungi
RE: Welding simulation
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
I'm looking for software adding elements…. my problem is that my part "explodes" after welding… and the FEA stress simulation of the completed weld shows no problems with residual stresses… that’s why I want to have look at what happens, with the part, during the welding… and I hoped a proper simulation could help… maybe you have any suggestions?
Best regards
Jungi
I know Ansys can do something very close to what you need (but not "exactly" what you need...) with its "birth-and-death" functionality. I say "not exactly what you need" because, in order to make an element "live", it must already be there, so you deterministically "fix" the position of the elements BEFORE beginning the simulation.
Are you saying you have a physical part that is breaking after you've welded it and at a much lower load than you would expect it to? And you are trying to determine why?
The part, actually a shaft, breaks apart before the load is applied... the guys in the workshop just lifted it from its support then it happened... the weld goes over the circumference of the shaft, is not very wide but quite thick - multiple layer. I want to see what happens with the shaft exposed to changing thermal stress during the process of welding…
ah, now it's clearer... Well, if you are going to simulate that with FEM, good luck, because you will face a quantity of challenges:
- build a model with crack-growth possibilities
- build a model with birth-and-death possibilities
- get an extremely detailed/precise constitutive law for both the base material and the welding material, taking into consideration that the properties will be temperature-dependant
- build a model which can be solved efficiently because you will have to perform transient coupled-field analyses (thermo-mechanics), but on the other hand you will have to use some lots of elements for the HAZ and around the crack(s) if any
Before doing so, if you can, I'd try to determine the causes of failure by metallurgic inspection. Did you already radiographed the specimen? Was the welding controlled? And if yes, how? Do you know if the specimen already had defects? Cracks? Crack initiators somewhere in "critical" locations? Did you examine the fracture surfaces?
With data of these kinds, a good metallurgical specialist can in 90% of cases determine the mechanism and thus the cause of the failure.
I’ve checked the „birth and death“option for ANSYS, it should work… I also have quite precise material properties, temperature dependency inclusive… I think I can still take a look at the residual stresses during a transient simulation without taking cracks into consideration… just to see how big the maximal stresses are, and where they occur… it would be generally interesting to see if such a FEA simulation is possible and how much it fits the reality…
to simulate the welding process there is a module of MSC.Marc, based on Goldak theory.
The calculus is a thermal-structural coupled FEM simulation, the elements are activated in time and temperature through the path of welding.
I used Marc for a lot of simulation, but i'd never used it for Welding. Now i use Ansys, but for weld simulation there is only a spot weld element; i have only a mechanical license so for a transient thermal-structural coupled simulation a must do an upgrade to multiphisics license to simulate a similar calculus.
Best regards.
