Farm Irrigation Design Manual
Do you have any suggestions which is the most informative manual that I could use for the job. Do you any links of those excel spreadsheets used in calculating Main line Friction Loss, Single Manifold Loss, Drip Tubing Loss, etc.....
RE: Farm Irrigation Design Manual
Here you go
Irrigation
Bienvenido Al Ministerio De Fomento http://www.mfom.es/publicaciones/cgi-bin/catalogo?Us=42
Http--www.rowbotham.com-knowledgenet-countryprofiles-spain.p http://www.rowbotham.com/knowledgenet/countryprofiles/spain.pdf
Irrigation Pumps & Alternate Water Sources http://www.irrigationtutorials.com/pump.htm
Irrigation Sensor Graphics http://www.wateright.org/Sched2.asp
Mainline Pressure Loss (landscape Sprinkler Design Tutorial) http://www.irrigationtutorials.com/sprinkler09.htm
Winterizing Your Irrigation System http://www.irrigationtutorials.com/winter.htm
Ads Pipe Products Technical Support http://www.ads-pipe.com/us/en/technical/pipetech.shtml
California Wateright Irrigation http://www.wateright.org/Sched1.asp
Cit http://cati.csufresno.edu/cit/
Department Of Plant And Soil Sciences - Home Page http://pss.okstate.edu/
Dpla - Dpla Home http://www.dpla2.water.ca.gov/
Dwr California Water Page http://wwwdwr.water.ca.gov/
Irrigation Design - Landscape Sprinkler System Design Tutori http://www.irrigationtutorials.com/sprinkler00.htm
Irrigation Training And Research Center http://www.itrc.org/
Links To Water Conservation Websites http://www.irrigationtutorials.com/links/conservation.htm
National Irrigation Science Network http://www.nisn.com.au/
The Centre For Groundwater Studies http://www.groundwater.com.au/
Università Degli Studi Di Trento http://www.unitn.it/index_eng.htm
Water Use Efficiency Home http://www.owue.water.ca.gov/
Water Use Efficiency http://www.owue.water.ca.gov/
Watershed Management Planning http://www.mass.gov/dcr/waterSupply/watershed/dwmplans.htm
Waterwise On The Farm http://www.agric.nsw.gov.au/waterwise/
Welcome To Wateright Homepage http://www.wateright.org/
Www-virtual Library Irrigation And Related Topics http://www.wiz.uni-kassel.de/kww/projekte/irrig/irrig_i.html#index
Brampton Irrigation Inc., http://www.ilap.com/brampton/
Hunter Industries - The Irrigation Innovators http://www.hunterindustries.com/
Links To Full Line Irrigation Manufacturers http://www.irrigationtutorials.com/links/fulllinemanf.htm
Links To Irrigation Industry Websites http://www.irrigationtutorials.com/links/index.htm
Nelson Lawn Sprinklers, Irrigation, Landscape Products http://www.lrnelson.com/
Rain Bird Commercial Irrigation, Residential, Golf, Agricult http://www.rainbird.com/
Spring Brook Irrigation - The Lawn Sprinkling, Agricultural http://www.springbrookirrigation.com/
Toro Home Page http://www.toro.com/
Operation
Agricultural Pumping Efficiency Program - Pump Test http://www.pumpefficiency.org/getpumptest.htm#list
Http--www.itrc.org- Irrigation Scheduling http://www.itrc.org/ETWeb/WBandISHomePage.htm
Irrigation Scheduling http://weather.nmsu.edu/Teaching_Material/soil456/Irragation/index.htm
Scheduling http://www.wateright.org/
Associations
American Society Of Civil Engineers http://www.asce.org/
Cit http://www.cati.csufresno.edu/cit/
Eia http://eia.free.fr/
Irrigation Association Of Australia Ltd Home Page http://www.irrigation.org.au/
Irrigation Association http://www.irrigation.org/
Plug In To Your Profession - Gcsaa Online http://www.gcsaa.org/
South Aferican Irrigation http://www.sabi.co.za/
United Kingdom Irrigation Association, Ukia http://www.ukia.org/
Welcome To American Society Of Agricultural Engineers http://www.asae.org/
WinSRFR
hydraulic analysis of irrigation systems
From USDA
http://www.ars.usda.gov/services/software/download.htm?softwareid=164
Software
A Landscape Irrigation Design Software For Professionals http://www.irridesign.com/
Agricultural Software Directory http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/econ4118?opendocument
Bie Irrigation Engineering Software http://www.engineering.usu.edu/bie/software.html
Center For Irrigation Technology - Home Page http://www.cati.csufresno.edu/cit/software/
Http--www.cati.csufresno.edu-cit-software-spacepro_orderform http://www.cati.csufresno.edu/cit/software/spacepro_orderform_fill_in.pdf
Intelligent Irrigation Systems http://www.cohort.com.au/
Irrisoft - World Database On Irrigation And Hydrology Softwa http://www.wiz.uni-kassel.de/kww/irrisoft/irrisoft_i.html
Raincad Autocad Edition - Irrigation And Landscape Design So http://www.softwarerepublic.com/raincad_sx_ae.asp
http://virtualpipeline.spaces.msn.com
thanks a lot biginch!
thanks for the links.
