Wireless network
Wireless network
I'm trying to help my parents get out of the stone age and set up a network. They have three buildings they want to have internet acccess in. Two houses, and a metal building. The building and one house have metal roofs.
Everthing is basically a big triangle with about 200 feet between buildings.
Can I get a good wireless router to reach all areas? What is the best way to get things connected? I read about repeaters and uni-directional anntena. Can I get a signal amplifier.
I think I need to turn this over to the experts for some advice. Thanks.
RE: Wireless network
Is this out in the sticks? Are there a lot of other houses around and RF in the environment?
Keith Cress
I think I'm going to buy a wirless router and just test to see how far it reaches as a first attempt...
There is a Linksys repeater I have had marginal sucksess with. Make sure you check it out first so that you pick a router that it will pass-thru. (It's a box with a single antenna sticking out of it.) If you can't find it let me know.
There is the sure bet of using small Yagi antennas that will project the signal miles. You should also research that briefly so you get a usable router for that scheme if deemed necessary. (Connectors are the usual problem.)
Keith Cress
Keith Cress
