IEC Metric Motor Requirements
I am assisting a colleague on a project and need a little help on a question we have.
We are designing a product that utilizes a standard IEC induction motor and are adding some components such as a thermal overload and switch to the terminal box.  In order to do this we must remove the existing terminal block that comes standard on this IEC motor.
Is there a standard that requires the use of terminal blocks on IEC motors?  Every IEC motor i have seen has the terminal block setup.
I should include, it is a 115-230 single phase motor.
Thanks everyone.
RE: IEC Metric Motor Requirements
Why pray tell are you adding a thermal overload to the motor connection box? Bad idea IMHO.
I should have said switch\circuit breaker not thermal overload, sorry.
Check NEC Article 430 if the motor is larger than 1/3 HP.
