Non-convergence because of excessive distortion
My model does not converge because of (I think) excessive
distortion. Below is what I get from the msg.file
Please advise me how can I overcome this issue
               EQUILIBRIUM ITERATION     2
AVERAGE FORCE  1.642E+05   TIME AVG. FORCE    1.642E+05
LARGEST RESIDUAL FORCE -1.283E+04   AT NODE  3864 DOF  2
LARGEST INCREMENT OF DISP.   -0.273  AT NODE 8302 DOF 2
LARGEST CORRECTION TO DISP.0.128  AT NODE  8302   DOF  2
FORCE EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
RE: Non-convergence because of excessive distortion
Try decreasing the initial, minimum and maximum time increments.
Playing with the initial, minimum and maximum time increments couldnot solve the issue.
I am puzzeled about what the solver does when getting non-positive definite matrix (negative or zero stiffness matrix determinate) that could arise , for example,  due to material softening/failure. Keep aside the technique used in Riks Step as I can not use this step.
Here is some warning massege I am getting during the job run
"The plasticity/creep/connector friction algorithm did not converge at 1 points
Program is asked to invert a singular matrix"
