Hydrogen in Transformer Oil
What is the effect of Hydrogen in tranformer Oil?
How hydrogen form inside the transformer?
I hope you can help me on this..
pabs
RE: Hydrogen in Transformer Oil
Hydrocarbons in the oil have hydrogen in them, "Hydro".  Mechanisms that break down hydrocarbons can result in free hydrogen and many other gases.
Keith Cress
Hydrogen is typically produced from arcing or corona internal to the transformer breaking down the hydrocarbons. You need to look at the other gasses presnet to determine the cause.
corona in oil?  result hydrogen
Would this point to the oil breaking down or inpure oil in the transformer?
Would you do a test on the oil to see if it still has its insulating char?
Trends are more important than any one test result. Retest in a month or so. An upward trend would indicate an ongoing corona or arcing condition.
As I remember every type of malfunction in transformator leads to a different gases in transformator oil. I will try to find my notes where I have the table, but it is certainly some sort of malfunction. Try to find out from oil supplier that table it will give you a pretty good idea with what are you dealing with.
How does it get there?
Transformer oil consists of long chain molecules of hydrogen and carbon, hence the name "Hydrocarbon".  The long chains make a material that is liquid at normal temperatures and pressures.  These molecules are stable.
However, if something happens inside your transformer to elevate the pressure and temperature, the long chains are broken into shorter bits.  some of these fragments of the formerly long chains are gases like ethane, methane, ethylene and hydrogen.
These gases typically dissolve in the oil and some of them migrate out of the oil into the gas space of your transformer where they can be detected and analyzed.
Each gas is associated with a particular power level needed to crack the long chain of the oil into the smaller gas molecule.  Many scholarly papers are available concerning this phenomenon.
A phone call to Doble Engineering in Massachusetts will get you more information about gases in insulating oil than you ever thought possible.
old field guy
Thank you all for your answers to me.
I appreaciated it very much.
But oldfieldguy your my MVP..
pabs
