Cast Iron Service Temp
we are searching for a cast iron grade (alloy if so) that has a maximum service temp. of 1500 F or greater. searched Matweb & could only find 1350F.
Does anyone know of a grade that meets this crteria?
Thanks.
Thanks.
RE: Cast Iron Service Temp
It would be helpful if you could post the end use of the material in question as many things will preclude the use of CI at your temperature.
http://
The end use is in a carbon bake furnace flue port cover. They have used cast iron in the past, but we are not sure of the alloy or grade.
http://www.wescast.com/files/PDF/2004-01-0792.pdf
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
" All that is necessary for triumph of evil is that good men do nothing".
Edmund Burke
V
I've seen situations where a part was about to be replaced with a relatively standard stainless grade and the spectro test showed the original part to be monel. Cost us about US$150 for the test and saved us a lot of heartache.
LewTam Inc.
Petrophysicist, Leading Hand, Natural Horseman, Prickle Farmer, Crack Shot, Venerable Yogi.
Edmund Burke
