ALVENIUS PIPE SYSTEM
Grettins to everybody.
I would like to know if someone of you can help me with a problem.
I have pipes of 28, 30 and 32 diameter inch , I need to connect this pieces of pipes with Alvenius System K-10, but I don't the mesurements of the coupling ring that goes around the counter od the pipe, which connect with the .
Alvenuis coupling
I will appreciate any information
John
Mechanical Engineer
RE: ALVENIUS PIPE SYSTEM
Hello John,
I hate to see a posting with zero responses so I "googled" and I came up with this Internet address for "leaflets" descriptive if the ALVENIUS K-10 product line.
I hope it helps or points you in the right direction.
Regards, John.
JohnBreen
Was a web site to be listed in your post
I failed to see the web site that you had mentioned.
Hence, I located this one which may offer the information required by NAITSABES
www.alvenius.com
Hi STYMIEDPIPER,
Yes, I thought that I had included that address but not until your posting did I see that the cyber-gremmlins had erased it on its way to eng-tips.
I found Alvenius via google and then got down to the product descriptions and "leaflets" at this address:
http://www.alvenius.com/article.php?id=22
OK, I looked twice this time and the address is really there.  Thanks for your "heads-up"
Regards, John.
JohnBreen,
Ah! for a senior moment.
I had Googled and was about to post when your post appeared.
