Foreshortened Diameter in Detail View
I tried to use the search function for past posts on this subject but the search tool does not seem to be working for any query.
I am trying to add a few foreshortened diameters to a drawing detail view but it does not seem to be working. I can drag the diameter from another view but it does not stick.
[url=http://i mg185.imag eshack.us/ my.php?ima ge=forshor teneddiame terxd8.jpg]
[url=http://i
RE: Foreshortened Diameter in Detail View
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Dan
www.eltronresearch.com
Jeff Mirisola, CSWP
CAD Administrator
Eltron - I always use SmartDim's but I do not have the available option of selecting "foreshortened" as you have mentioned.
When you ctrl-drag the dim, are you dropping it on the cylinder edge? What version of SW are you on?
Jeff Mirisola, CSWP
CAD Administrator
Jeff Mirisola, CSWP
CAD Administrator
Are the diameter dimensions you are trying to use for the foreshortened dimensions created manually or by the Insert > Model Items function?
If manually, they must be created by selecting both sides of the outline/profile of the diameter ... not just the straight end of the diameter? ie. It must be a true diameter dimension, not just a linear dimension with a Ø symbol applied. Is the Ø symbol automatically applied?
I have 2 idential bore diameteres (one on each side of the part). My detail view comes from the section view and I was inserting the diameter via "Insert Model Items" and selecting the bore on the opposite side (not the side with the detail view, if that makes any sense. Once I flipped the direction of the section view I was able to do it. This may be what JMirisola was trying to tell me.
Thanks for all the help :))))
